koukouroukou Posted September 7, 2004 Report Share Posted September 7, 2004 I just got the NH1 and it had 3 spare clamp filters that according to the instructions should be used with the remote and with line in/out cables and mic.... Ok...are they necessary? What interference could the remote pic up?? Quote Link to comment Share on other sites More sharing options...
jadeclaw Posted September 7, 2004 Report Share Posted September 7, 2004 RF-interference from nearby transmitters, notably AM-radio and shortwave transmitters. In most cases, they are not necessary, but if you hear things, that shouldn't be there, you should use them. The short remote cable is the smallest problem here, the biggest one are long cables into a home stereo or a long microphone cable. Quote Link to comment Share on other sites More sharing options...
koukouroukou Posted September 8, 2004 Author Report Share Posted September 8, 2004 Well ok...if i were to use it with a home stereo i wouldn't mind the clamp filters...but on the remote....that would suck... Thnx.. Quote Link to comment Share on other sites More sharing options...
