Reformatting PC, need to backup SS database -- advice?
doclloyd
I am in the planning process of backing up any necessary data off my PC and reformatting my Windows partition on my desktop. I currently have a 11GB sonicstage database that needs backing up. I have a drive where I can back this data up while I reformat the main drive. My questions are:
* What process did you use when "moving" the database?
* Was it seamless? Any issues?
* I also have some tracks via Sony Connect. Is the deauthorization/reauthorization process a problem? I will be contacting their tech support as well to make sure my bases are covered.
* Do you run the "verify" portion of the backup process? Is it even useful?
I'll appreciate any caveats I should watch out for. Thanks in advance.
