SS 2.0 upgrade + Vaio = no cddb
Raify
Since upgrading to SS 2.0, cddb no longer works (I have tried changing the proxy settings)
I am running Xp home on a Vaio, so according to the FAQ's:
  Quote
How to properly reinstall NetMD:
WARNING: If you use a Sony VAIO with preinstalled software provided by Sony or use other software developed by Sony, do not follow the procedure below.
I didn't follow the uninstall everything, clean resgistry method. I just upgraded to SS 2.0 and everything seemed to work fine.
Is there something simple I'm missing? Or do I really have to un-install everything, fiddle with the registry and start again?
Thanks in advance for any advice!
Nathan
