problem with transfering from MD to computer
don_alvaro
Hello,
I've just received my Sony MZ-NH700 and wanted to transfer a (live) Mini-Disk recording via USB cable and Sonic Stage onto my computer. I wanted to play the MD recording with Sonic Stage and record the digital stream with "Total Recorder" - but it didn't work... Every time I want to play the Mini-Disk recording on the computer I can only hear it on the headphones of the MD Recorder and I can't hear it on the speakers of my computer - and Total Recorder has no audio signal to record. Disconnecting the headphones doesn't help as well as putting the volume higher.
I hope someone can help me!
Best wishes from Germany,
Tim
Transfer from standard MDs [sP / MDLP modes] must be done by analogue means.
Use a 3.5mm - 3.5mm stereo cable from the headphone output of your NH700 to the line-in on your sound card.
Make sure to disable EQ and AVLS, and turn the volume all the way up. To actually get line-level signals you will have to increase the input level a bit.
