where to find the complete installer for Sonicstage 2.2 ???
tartan
Where can the complete and whole installer for Sonicstage 2.2 be found ???
Don't want the "incomplete" version which requires connection to the web to install but want a "complete" installer which will install when the computer is not connected to the web. It must also be the one which can burn music or MP3 cd's
Someone please answer this as soon as possible.
The reason is that 2.2 can burn music and MP3 cd's and not just atrac cd's, and this feature may be removed at anytime, with the web connected installer, it is vulnerable to downloading an "updated" Sonicstage 2.2 which will only burn atrac cd's while a "complete" installer is not influenced by this and will burn mp3 and music cd's even if this feature is removed sonicstage 2.2
Download the one using the connect web connection. When it starts to install you will have to click next. DONT!!!!
Goto your temp folder (windowstemp or under XP its Documents&settings/"your login name"/Local Files/temp) and copy the SonicStage temp folder to a new folder on your HDD. You now have a version that can be put onto CD and used whenever you need to re-install.
As for a downloadable version of it, sorry dont know of one that does not use the web-download feature.
That installer is too smart. It would only get an "upgrade pack" and not get the complete installer.
Already got 2.1, and don't feel like upgrading it yet, also want to be able to install 2.2 straight away without first installing 2.1.
Still interesting in snagging the upgrade pack too.
Does it say "next" after it downloaded all the required parts but before installing begins (the time to copy) and can the installation material dug from the temp folder be opened like any .exe or must it be tricked into working ???
