Recording life of LIP-4WM Lithium Ion Battery?
emptyzero
NH1 uses a lithium battery that is (afaik) only available in one size as it is only used in the NH1 & the playback only version of the NH1 (NH3D?).
Yes it will record a 50 minute program easily. It will probably record 6 of them one after the other if you are using Hi-LP or 4/5 in Hi-SP.
If you are going for the longest recording time on one charge, I think its Hi-LP on a MD disc in Hi-MD mode (not the 1GB disc).
http://www.audiocubes.com/product_info.php...ate_banner_id=1
the Sony LIP-4WM Lithium Ion Electric Battery? found that link in the batteries thread. Battery and pre-amp are the next purchases. Is there a better place to get one?
Edit: sorry, I'll stop making a thread for every question I have...quickly trying to pound out those newbie bugs.
