volcs0 Posted October 15, 2004 Report Share Posted October 15, 2004 I am not a MD owner (yet). I'm trying to convert optical audio (TOSLink) to analog (RCA). Will this do the trick? Do I have to be recording in order to monitor the sound? Thanks. Sam P.S. Sorry if this is the wrong forum for this - I did the best I could. Quote Link to comment Share on other sites More sharing options...
Syrius Posted October 16, 2004 Report Share Posted October 16, 2004 Yes, it will. You will need to have the unit in record-pause, with a disc inside of it. (Which I don't recommend, since it can cause wear on the motor) Sony MD decks have a feature that converts the signal to analog, so you can monitor, without having a disc inside. Darn. I miss my JE 330 deck. Quote Link to comment Share on other sites More sharing options...
volcs0 Posted October 16, 2004 Author Report Share Posted October 16, 2004 Would this do the trick? http://www.amazon.com/exec/obidos/tg/detai...e&s=electronics http://snipurl.com/9t38 Thanks. Sam Quote Link to comment Share on other sites More sharing options...
Syrius Posted October 24, 2004 Report Share Posted October 24, 2004 I thniks so. I had a 330 deck, and it could act as a DAC even without a disc. Simply hit "rec" and that's it. Sony implemented this as a feature to monitor your digital stream without recording. Very smart, I say. Quote Link to comment Share on other sites More sharing options...
