Uploading from MDHI to PC troubles
ngunsl
Hi
I have tried to upload from the minidisc player MZNH1 music files to pc. It sound that process goes on but then no chance to locate the uploaded files on the pc. i tried in several ways with md and hi formats. Worst is that it deletes files from md even if in option i specified to keep copies on md! Has anyone faced same!
N
The only recordings you can upload from HiMD using SonicStage, to my knowledge, are those recorded from the analogue inputs on the recorder. Copying music from somewhere else with another copy omf SonicStage will not work.
Copying optical recordings might, but I have no way to test it. If they were following SCMS rules, they may or may not be - depends on the source it comes from. Copying from a CD to HiMD, then to a computer, should -not- work, for instance.
