Important Newbee Q!! Pls help!
rumsbums
Hi there!
I got a big problem, hope u can help me!
well i bought a sharp im-dr420h md player and a microphone for it to record my guitar playin. i was really happy when i heared which great quality the records have. but now i got a huge prob.
with the sharp md player was the beat jam program, which only allows loading data from pc and then back to pc.
when i tried to load up my own recordings an erroer message appeared.
u know its the open mg thing...
so i wanted to ask u if theres any other way to load the data digital via usb cable on pc.
maybe some other program or hack or so?
i hope u can help me
Deck in this scence of the word would mean a Hi-Fi unit or system
Basically no portable device has a digital output socket (optical or coax), most hi-fi units do have this feature though & this would allow you to connect the hi-fi upto your PC soundcard (as long as it has a digital input) & record digitaly.
