Stuck on transfering song(s)
fld
SS: SonicStage 2.x (latest)
Cpu: AMD64 3000+
Mobo: GigaByte GA-K8N (alsu using onboard sound card 'Realtek WHQL 3.62')
OS: WinXP Pro (with SP1; SP2 doesn't work well for me)
MD: MZ-N610
Problem: Unable to transfer songs
It will get stuck anywhere out of 100% (i.e 31%, 53%, etc..) during coverting or actually transfering the song.
*I've also tried all the method to fix this problem, which I found this forum and a few others. No result yet, no improvement or whatsoever.
If you have occur this problem please reply with your method to fix this.
Or if you know what I can do to fix or any help will be great.
Thank you.
Before with Service Pack 2 -slow down system
-locked up directories (My Computer, My Documents, etc..)
Recently (today) with Service Pack 2
-installed SP2 again
-use a valid cd key
-all system running smooth
After I installed SP2 I tried another attempt to transfer songs to my md; still no luck (same problem occur again).
So I decided to try using RealPlayer, which I recently found out you are enable to transfer song with it by reading the forum here.
Result:
-transfer success
-quailty bad
Is there some codec I need for RealPlayer (i.e ATRAC) ?
