SS 2 = Still no CDDB!
Raify
it works for me
to do it yourself try pressing ctrl + I when connected to the internet.
also you should update to ss 2.1/2.2
via either www.connect-europe.com or www.connect.com
location dependant
if this dosen't solve it got to
tools -> options -> get cd info -> cddb
register for cddb
click detailed cd info
make sure you have the proxy settings sutible for you [trial & error]
I said SS 2.0 out of habit. I downloaded it only last night from connect website, so it must be the latest version I have (whatever number that is)
I've tried playing with the proxy settings (tried all three) with no success.
Unless anyone knows what server adress I can specify?
Pleeeeease someone help, or I'm going to give up and get an iPod....
I lost CBBD after I installed my Creative Labs sound card. I installed the media centre with it & after that point CBBD crashed or just closed every time I started it, uninstalled CLMC and it worked again.
Check for other CBBD programs and try and uninstall if you can. (BTW that is the only one that caused it to fail, I have other CBBD programs but they seem to work ok together)
