bdawg Posted November 4, 2004 Report Share Posted November 4, 2004 Hi which minidisc units do you recommend for recording lectures. I need a unit that can upload. thanks Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted November 4, 2004 Report Share Posted November 4, 2004 The Sony MZ-NH900 will give you the best recording battery life of the current Hi-MD recorders. Alternatively the NH700 would also give you respectable results if you are looking for a more budget model. It depends on how much you want to spend really, and which features you're after... Quote Link to comment Share on other sites More sharing options...
bdawg Posted November 4, 2004 Author Report Share Posted November 4, 2004 thanks. someone posted that the 900 has a digital amp? what does that mean? Quote Link to comment Share on other sites More sharing options...
Christopher Posted November 4, 2004 Report Share Posted November 4, 2004 bdawg, there is some basic [yet a bit outdated] info here. Quote Link to comment Share on other sites More sharing options...
