Durability of the more expensive earphones/E2 v ER-6
sknight
Before I take the plunge into the realm of the expensive earbuds, I wanted to get feedback on how well they fare through years of usage. Such things as poor contacts, cable pull, and simple long term deterioration through usage.
A trick I've used on my Sony earbuds is to put a drop of Krazy Glue whereever the wires go into something. The plug, the earbud, and any bushings. I've found that this has been very effective with keeping the wires from pulling out and damaging the solder joints.
Just a small drop, enough to make a bond. If there's a bit the wire can go into the connection, push it in, to relieve the stress before you glue them.
Hmm.
Not owning any very expensive earbuds myself (my most expensive pair being Shure E2cs, which are not expensive) I would only guess that some would be more fragile than others.
I believe that Etys are rather rugged, but taking care of them would make them last even longer. They certainly appear to be designed with durability and repeated use in mind.
I was also wondering about the service life of the internal components.
Thanks.
I'm about to take the plunge into the "higher priced" earphone realm.
I'm thinking between the Shure E2, Etymotic Er-6, and the Audio-Technica earbuds I posted on another thread here. I'm researching right now. The only thing turning me off about the Er6's is that the frequency response ends at 16khz.
I have the Etys (Er-6i) coming by UPS tomorrow. I'll let you know how they work out.
I chose them over the Shures, because apparently they make voices sound clear, and not muffled...
Edit: So it turns out that they're wonderful. I used to have to have my MD volume turned up to 28/30 to hear anything, now I can keep it down at about 14/30 or 15/30.
I'm really pleased with the sound quality... they have actually turned me off of mp3s, because the sound is that good, and they show the lack-of-quality in the mp3s. But my CDs and MDs sound gorgeous... it really does sound like the singers I listen to (classical sopranos) are right inside my head.
And they block out sound quite well... I've been experimenting with the TV.
Hope that helps...
Please do not post duplicate threads - keep your (related) questions in the same thread. This time I've merged it for you, but the next time I'll just delete it.
It's pointless to ask what the preferences of others are in this case since the E2s and ER-6s sound entirely different. It's not as simple as comparing which has a stronger bass and which is more detailed, but the way each earphone sounds as an overall experience.
Listen to both and do a comparison for yourself. It's not something that can be compared scientifically.
  Quote
It looks like I've decided on the E3.  Partically on more recommendations, as well as the price factor.  They can be had for just a few dollars more than E2's.  It seems to be a worthwhile jump for a bigger difference in performance compared to what I'm using now.
Just a few dollars? Waaaaii, link me, link me!
I bought my E2cs for ~70USD. The cheapest I've seen E3cs for have been more than double that price!
