Slow file transfers?
enriquez
Yep, that speed looks about correct.
Remeber that the unit only does 9Mb/s when using a Hi-MD disc (even slower using an old MD). This means that 2-3x is about the best you can expect from an MD copying WAV files.
If you need high speed transfers then I would probably use Hi-SP for recording as it will generate a smaller file with only a silight (personally un-noticable) loss in quality (Discs can also hold more as well).
