N-510
Embio
Yes
Works great, but there are a few catches.
The LCD display won't show all the information, so while you can still use the equalizer function, you won't be able to see where the level is set. It's pretty easy to just count how many button pushes up down and over, to keep a mental note while you're setting it though.
Also, the melody timer only displays the 10s column, so again it's counting button presses. the PDM doesn't work, because it loses it's memory when the system loses power. And the system loses power when you open it.
On the up side, Line Out works great, EQ works great (see above), Timer, the function to speed up and slow down (forget the name of it. all work great. It's a worth while hack.
I'm not sure if there were other functions added, It's been a while since mine has been at it's factory settings.
I started a thread about the hack specifically for the 510 quite a while ago, but it should be easy to search for and find.
Also, I wasn't able to do the hack without the remote. You can get into service mode, but the navigate, I needed the remote. I also had and older firmware (1.2) so that may or not make a difference. the hack is the same for all versions though.
good luck
-Jeff
