Auntie MD Posted November 14, 2004 Report Share Posted November 14, 2004 When I put my MZ-N1 in ManualREC to control the input volume manually, the volume numbers go up or down normally, but the volume bars indicate the volume actually didn't change. And when testing by changing the volume in the middle of recording and listening to the result it's apparent the record volume didn't change. This happens with both the mic input and the line input. Auto REC still seems to work normally and the volume control still works normally for playback. Nothing got overvoltaged that I know of. Is it fixable? Thanks. Quote Link to comment Share on other sites More sharing options...
Syrius Posted November 14, 2004 Report Share Posted November 14, 2004 I think you have to let the unit in record pause in order to change the settings. AFAIK, only Sharp units let you adjust the levels on mid recording. Quote Link to comment Share on other sites More sharing options...
Markr041 Posted November 14, 2004 Report Share Posted November 14, 2004 You do NOT have to put the unit in pause mode, while in manual recording, to change the levels - they change by number x/30, where x is your setting. You can change in pause or while recording on the fly, just like the Sharps. Does anyone else have the experience that changing the numbers on the fly actually does nothing to the actual recording volume? Quote Link to comment Share on other sites More sharing options...
Auntie MD Posted November 14, 2004 Author Report Share Posted November 14, 2004 Hey don't bring that fight over here. Anyway, I tried it in every mode possible. It used to work. Quote Link to comment Share on other sites More sharing options...
