FS: Pioneer MEH-PO77 MDLP MiniDisc Car Receiver
Ryzir
I am selling this for $375USD + Shipping. This deck is less than a year old and in Mint condition. It has absolutely no scratches on the face and has been Professionally installed and un-installed. It comes with an AUX input adapter so you can plug your laptop, Hi-Md player, mp3 player, etc. directly into the deck. This is a Japanese Unit but has an FM Frequency Converter so you can get US radio stations. If you are interested email-> ryzir@cashette.com.
Actual Photo of the Deck:
user posted image
Features
MD-auto gain control
ASL-"Auto-sound-levelizer"
DSP
9-band graphic equalizer
Selectable subwoofer cutoff frequencies
Specifications
Input/output terminal
RCA: Output or non fading output
IP bus: Input
Amplifier section
Installed capacity: 50W״
Audio section
Output terminal
-Cutoff frequency: 50/63/80/100/125Hz
-Cutoff slope: - 12, - 18dB/oct
-Phase: NOR/REV
-Span of adjustable range: +6 - - 24dB
High pass filter
-Cutoff slope: - 6, - 12dB/oct
9 band parametric equalizers
-Frequency: 50/100/200/400/800/1.6k/3.15k/6.3k/12.5kHz
-Span of adjustable range: ?12dB
Loudness (volume): - 30dB
Pre-out installed capacity level: 1.8V/1k Ω
MD player section
Frequency characteristic: 20 - 20,000Hz (?1dB)
Signal-noise ratio: 90dB (1kHz) (IHF-A network)
Dynamic range: 90dB (1kHz)
Tuner section
FM/AM
Practical speed
-FM/8dBf (0.7 μ V/75 Ω, mono and SIGNAL-TO-NOISE RATIO: 30dB)
-AM/18 μ V (SIGNAL-TO-NOISE RATIO: 20dB)
Common section
Largest consumed electric current: 10.0A
Installation size: 178 (W) ׵0 (H) ױ62 (D) mm
Mass: 1.2kg
Accessories
Main unit, 1 remote, manual, warranty card
