Backing Up
aamd
I've read a few posts talking about backing up your tracks before transferring them in SonicStage. Is this simply a matter of transferring all the files from my 900 to a directory on my PC? If something were to go awry, would I simply transfer them back to my MD and then try to upload them back thru SS?
I managed to successfully transfer my son's concert using total recorder, but would love to just drop and drag.
Thanks,
All my CD rips are MP3 at 96 or 160bps (depends on my need) and primarily backed up onto CD-Rs. Only then will I use them in Sonic Stage. ALWAYS have backups of anything important.
Ild use an MD recorder for a concert if I were you. If the upload fails for some wierd reason you can always transfer realtime anyway. Assuming youre using a HI-MD recorder.
The key is after the transfer use Sony's wav converter or MarC's himdrenderer to convert the file in Sonic stage to Wav or MP3 and the BACKUP somewhere.
