Dark_Neo Posted December 7, 2004 Report Share Posted December 7, 2004 I've brought a N505 off eBay, got it cheap cos the headphones don't work properly, thought it would be a quick fix, turns out it's a bit more complicated than I thought. The problem isn't with the headphones or the internal connector. For some reason the beeps and the timer alarm work fine, just not the music. I've found the cause of the problem though. Look at this pic http://notacake.com/minidisc.jpg I'm not exactly sure what that is but it seems like a switch. It was originally covered with a round rubber pad the was being pushed down by the back of the case, but the case had dug into the pad too much and was no longer applying enough pressure. When pressure is applied to this switch/chip the sound comes on. I've tried replacing the rubber pad with other rubber/foam pads but it doesn't fix it for long. Is this a common problem? and more importantly, how can I fix this permanently? It doesn't seem to be actually broken, so I don't see any reason why it can't be fixed properly, I just can't think how.... Quote Link to comment Share on other sites More sharing options...
Qwakrz Posted December 7, 2004 Report Share Posted December 7, 2004 I cant see much with that picture, any chance of changing it for one that is in focus so that its possible to see what it is? Quote Link to comment Share on other sites More sharing options...
Dark_Neo Posted December 7, 2004 Author Report Share Posted December 7, 2004 Sorry my camera is awful close up, none of the focus settings make it any better. It doesn't seem to be that anyway. It just needs pressure on that area of the board....I can't figure out why.....I also works if I lift the edge of the board up by moving the headfone conector down.... Quote Link to comment Share on other sites More sharing options...
Syrius Posted December 8, 2004 Report Share Posted December 8, 2004 Seems like a loose connection on the headhphone jack itself, and pressure is what makes the contacts touch. Quote Link to comment Share on other sites More sharing options...
Dark_Neo Posted December 8, 2004 Author Report Share Posted December 8, 2004 Yeah it seems that way, but it's still strange, since the socket itself doesn't seem lose at all, and the connections inside the connector are fine. I'm going to try and get a multimeter off someone and do some more testing. Quote Link to comment Share on other sites More sharing options...
