Boostaroo Headphone amp
mrsoul
Hopefully Cori will chime in about this business as she's pretty knowledgeable. I've heard some decent things about the boostaroo, but if I were to buy commercial I'd probably go with:
http://www.fixup.net/products/index.htm
..the Super Mini or Super Micro. They're a little expensive however, so it may not be the best solution. I believe your best bet would to DIY, but that's my opinion.
Eww.
Stay away from that. =P
Better suggestion is to buy a CMoy headamp. Drew of Shellbrook Audio makes a really nice CMoy in a tiny little Hammond aluminum enclosure. It's rather sexy.
If you're handy with a soldering iron, you could also make yourself a maxed out CMoy for about 40USD. For about twice that, you could make a respectable MINT amp, my portable amp of choice. :rasp:
http://www.tangentsoft.net/audio
Check it out, and search the Head-Fi DIY forum for more information.
Yeah, they suck.
For headphone applications though. For your purposes though, you want to use it because the volume is too low because of the way you recorded to use on your car deck, yeah?
If that's the case, I wouldn't blow money on a headphone amp, unless you plan on using it as a headphone amp, otherwise, it's an expensive waste of money.
I might need something to boost the line out signal for listening only during the time it takes me to get home from the place I recorded the show. Most of the time, that is usually an hour or more. I have just found the headphone output to be low and I don't even have the deck yet but just in case, I was looking around to see what I might be able to use to boost that signal. Once, I get home and get it uploaded, I will normalize and it's good to go from there .
