ballsandy Posted December 15, 2004 Report Share Posted December 15, 2004 I recently bought at a second hand store a lcd remote control with an fm tuner with the model number:RM-MC37LT. I use the MZ-N505 and the remote is semi compatible when the two plastic grooves are filed down but two pins are not used. Since the tuner and the screen is not running when it is plugged in, i am guessing that the two not used pins deliver power to the remote. Is there a way to install an external power supply so the lcd screen and tuner works? I need to know because it can't be returned in two days and (cough) it cost $40. Quote Link to comment Share on other sites More sharing options...
JeffS Posted December 15, 2004 Report Share Posted December 15, 2004 Nope, That remote only works with MD units designed for a tuner remote. If the extra grooves were filed down so that it slides into a regular MD remote port, I question if it would even work on the unit it was made for. Dump it quick and get your money back. -Jeff Quote Link to comment Share on other sites More sharing options...
ballsandy Posted December 17, 2004 Author Report Share Posted December 17, 2004 I will see if i can. But i have a feeling that they will not want it back because i filed the grooves down. I do know that the remote works on my player but the screen will not run and the audio plug was designed differently. I will try to see if i can find a different plug from sony that they will send me. I am pretty good at soldering but i still don't knowifthe screen will work. Thhe remote input on my player has 4 connectors. The remote plug has 6. Two connectors do not toutch the contacts so they must be for delivering power to the unit, or something else. I hope this works. Note: i use the sony MZ-N505 player/recorder Quote Link to comment Share on other sites More sharing options...
JeffS Posted December 17, 2004 Report Share Posted December 17, 2004 If you can dig up schematics for the remote you have and the remote that works for your player you MIGHT be able to rig it up. I doubt it would be easy, but if you like to tinker, go for it. Quote Link to comment Share on other sites More sharing options...
