Ministero Same As Mic Imput?
ROMBUSTERS
ya its a serteomini and yes for some reason, in a fit of lunacy, i thought the line in was digital only. Anywho works great now, except when Mr. Volume control makes it all sound the same. Meh guess ill be trying manual next.
BTW if I'm going from something like my CD player to my MD what recording level do you find good? Should I put the CD player on full/half volume? Should I use Loud Music recording option, etc?
Edited by ROMBUSTERS
tbh if it's from a cd player i'd use the optical option or via the PC. likewise when i record a vinyl record my chain i sthus
turntable -> preamp[mixer] -> pc using soundforge 7.0 [coverted to wav & tagged] -> sonicstage to md -> [back up] wav burned to cd
you could also use GNUfreeware like audacity. this gives you the option of cleaning up scratches & pops if you like & normalising
