Guest Guest Posted August 22, 2005 Report Share Posted August 22, 2005 Can you please let me use the same registration name that I currently have over at MDCF? I was hoping to be able to continue to use Weaves. However, the registration process tells me this name is already taken.WeavesNow Own: MZ-N707; NW-E507, and NW-HD5 Quote Link to comment Share on other sites More sharing options...
Guest Weaves Posted September 1, 2005 Report Share Posted September 1, 2005 Any update on this request?ThanksWeaves Quote Link to comment Share on other sites More sharing options...
Christopher Posted September 1, 2005 Report Share Posted September 1, 2005 I'm sorry for taking so long. I'm not seeing any account named Weaves. Are you still having problems? Quote Link to comment Share on other sites More sharing options...
Guest Weaves Posted September 3, 2005 Report Share Posted September 3, 2005 Kurisu,No problem, sound like your hands are full these days (with new gear, like myself ). Anyway, I just wanted to describe in detail what I think I should be able to do:1) I figured that the MDCF and ATRAC Life forums were using the same database for users. Therefore, I should be able to continue using my MDCF user name (Weaves) over here. False=I could NOT log in over here using the same user name and password as MDCF.2) So then I assumed the two were not related, so I would simply create a new user name over here that is the same as MCDF. False= When I go to create my registration over here, it seems to validate against MDCF and tells me the name is already in use.I think I should be able to use the same name in both places, correct? However, per #1 and #2. I can't create the user name of Weaves over here. I was hoping to avoid having to create a Weaves1, etc.Thanks WeavesNow proud owner of MZ-N707, HD5 (Black), NW-E507 (Silver Bullet, with homemade lanyard). Quote Link to comment Share on other sites More sharing options...
Christopher Posted September 4, 2005 Report Share Posted September 4, 2005 Create a name that isn't Weaves and then reply to this thread and I'll change the new name to the old one. I'll look into this further. Quote Link to comment Share on other sites More sharing options...
Weaves_ Posted September 4, 2005 Report Share Posted September 4, 2005 Kurisu,Done. New user name is Weaves1.Thanks Quote Link to comment Share on other sites More sharing options...
Christopher Posted September 7, 2005 Report Share Posted September 7, 2005 You should have a confirmation e-mail stating the change. Sorry about the trouble. Quote Link to comment Share on other sites More sharing options...
