ianspotting Posted January 10, 2005 Report Share Posted January 10, 2005 I tried to record some stuff on the weekend, and I lost all of it, it gave me an error, after I record. I deleted all the stuff of the disc. Do I have to do some sort of reformating of the disc before I have to record? Quote Link to comment Share on other sites More sharing options...
streaml1ne Posted January 10, 2005 Report Share Posted January 10, 2005 I tried to record some stuff on the weekend, and I lost all of it, it gave me an error, after I record. I deleted all the stuff of the disc. Do I have to do some sort of reformating of the disc before I have to record?←Not usually. If it was a blank disc to start with that should be sufficient. What model recorder are you using, and what type/brand of minidisc? Quote Link to comment Share on other sites More sharing options...
ianspotting Posted January 11, 2005 Author Report Share Posted January 11, 2005 Not usually. If it was a blank disc to start with that should be sufficient. What model recorder are you using, and what type/brand of minidisc?←I've already recorded on it and it worked fine, I then erased the information with simple burner, and now it's empty but doesn't seem to want to reord. I have a 700 model I believe Quote Link to comment Share on other sites More sharing options...
