Umd
Embio
for the user music portion it relies on Memory Stick to hold the media. Basically you transfer the songs you want from your PC to MemStick and then plug that into the unit, but as I've mentioned before other than SS there is currently no encoding software for Atrac3+ and SS doesn't recognize MemoryStick transfer. MP3 playback will be fine though
Edited by ROMBUSTERS
