sazmeise Posted January 15, 2005 Report Share Posted January 15, 2005 I want to use the wav conversion tool, but to install that i have to upgrade my sonic stage to at least version 2.1 (i think).So i downloaded version 2.1 but it would not install because i wasn't connected to the internet. I dont have an internet connection or phone line in my house (student houses - go figure) so is there any other versions of Sonic Stage above 2.0 that don't require an internet connection??Thanks,Saz*** Quote Link to comment Share on other sites More sharing options...
OCedHrt Posted January 16, 2005 Report Share Posted January 16, 2005 sazmeise said: I want to use the wav conversion tool, but to install that i have to upgrade my sonic stage to at least version 2.1 (i think).So i downloaded version 2.1 but it would not install because i wasn't connected to the internet. I dont have an internet connection or phone line in my house (student houses - go figure) so is there any other versions of Sonic Stage above 2.0 that don't require an internet connection??Thanks,Saz***←I can supply you with a full installer that will run offline. But you'd have to get it onto the offline computer yourself. Quote Link to comment Share on other sites More sharing options...
Christopher Posted January 16, 2005 Report Share Posted January 16, 2005 http://forums.minidisc.org/images/SS23ENG.exe Quote Link to comment Share on other sites More sharing options...
Christoph Posted January 19, 2005 Report Share Posted January 19, 2005 kurisu said: http://forums.minidisc.org/images/SS23ENG.exe←Hello,I just bought a nh900, didn't go tit so far , but I also want to upload and than convert recordings to wav files and as far as I have read, you need SS2.3 for it. Now my question is: is this exe the american version our the european version?I installed for a test both on a work computer ( with internet connection) and depending on the version you have the connect music store is either US or EUR, which does make a differnce, 'cause you can't shop in the US from Europe. Quote Link to comment Share on other sites More sharing options...
