Simple Burner Pcm --upgrade Ss 2.3 Required
1kyle
Just a note to all those who've downloaded the upgrade to Simple Burner Version 2.0.04.18080 trying to get the recording mode to PCM to work or even show in the menu
If it doesn't work you might have made the same mistake that I did -- You need to upgrade SS to version 2.3 as well (or at least ensure Open MG secure module version number is 4.05.10290 then it works 100%.
I had version 2 of Sonic stage with the Open MG secure module version number starting with 3. After upgrading it ran fine and the PCM option was present as well.
For downloads see the thread http://forums.minidisc.org/index.php?showtopic=7812
Thanks guys for posting the links -- great to be able to use PCM with Simple Burner.
Cheers
-K
Edited by 1kyle
I was the one who pointed out that PCM feature and ..I can say that your statement are wrong!
my SS version is 2.2
and OpenMG Secure Module : 4.0.00.05270, it's just that instead of using the SS version that is on line, just install the one that is included with your Hi-MD device (well for europeen consumers it works for sure!)
Mine came with SS version 2.0 and the older MG module. I bought my NH-1 in Stockmanns --biggest shop in centre of Helsinki Finland.
The point of the post was to say that if you upgraded the MD simple burner and you DIDN'T get the PCM option on the menu then I was merely stating a possibility that you need to update BOTH SS and the MD simple burner.
I'd imagine places like France and for sure Singapore are likely to have many more sales than Finland so you've probably got one with the later version of the Software.
I wasn't attempting to mislead people --merely explain what might be the problem if you DIDN'T get the PCM option which I didn't and a few others have also experienced the same problem.
(There's still quite a few people still using SS 2.0 and even 1.5 I think.)
Anyway thanks for posting the software -- it works for me now but it didn't until I'd upgraded SS --version 2.2 might have been sufficient as well -- I had version 2.0 and got 2.3 from this site.
Cheers
-K
Edited by 1kyle
