mufc4eva Posted January 24, 2005 Report Share Posted January 24, 2005 1st of all... Hello to you all Now just wondering if you can help me out with my problem here I keep gettin this message when I go to transfer songs I have wiped the disc clean (tried 4 or 5) and also tried to reinstall the software but had no luck at all If anyone could help me then that would be great Thanks! Quote Link to comment Share on other sites More sharing options...
mufc4eva Posted January 24, 2005 Author Report Share Posted January 24, 2005 Also just upgraded to the latest version of SonicStage but still no joy Any help would be great Thanks Quote Link to comment Share on other sites More sharing options...
mufc4eva Posted January 25, 2005 Author Report Share Posted January 25, 2005 Anyone? Quote Link to comment Share on other sites More sharing options...
mufc4eva Posted January 25, 2005 Author Report Share Posted January 25, 2005 Take it Newbs int allowed help Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted January 25, 2005 Report Share Posted January 25, 2005 well if that screenshot is the version your running, your clearly not running the newest version.try uninstalling all of your SonicStage/OpenMG/Simple Burner software following the instructions on this site (do a search).then go to connect.com and download SonicStage 2.2then do a search to find the updater for 2.3alternatively you could do a search on this site for the full installer for 2.3 Quote Link to comment Share on other sites More sharing options...
mufc4eva Posted January 26, 2005 Author Report Share Posted January 26, 2005 ThanksI will give that a go Quote Link to comment Share on other sites More sharing options...
mufc4eva Posted January 26, 2005 Author Report Share Posted January 26, 2005 Still the same Anymore help would be great Quote Link to comment Share on other sites More sharing options...
Syrius Posted January 27, 2005 Report Share Posted January 27, 2005 Are you using SP 2? Quote Link to comment Share on other sites More sharing options...
zerodB Posted January 27, 2005 Report Share Posted January 27, 2005 Before installing SonicStage version 2.3, did you do this? Quote WARNING: If you use a Sony VAIO with preinstalled software provided by Sony or use other software developed by Sony, do not follow the procedure below.1. Uninstall all OpenMG related software via the Add/Remove Programs control panel and reboot as necessary. This includes, but is not limited to, OpenMG 2.2, related 'Limited Patches' and the 'Secure Module', SonicStage 1.x/2.x, Simple Burner 1.x/2.x, and software by RealNetworks. Make sure that you unplug your unit before doing so.2. If you run Windows XP/Windows 2000 Professional, proceed to delete the following directories: "Documents and Settings\All Users\Application Data\Sony Corporation", "Program Files\Common Files\Sony Shared", "Program Files\Sony".3. Start -> Run -> regedit. The 'Registry Editor' utility should appear on your screen. Delete the references to OpenMG located under 'HKEY_CURRENT_USER\Software\Sony Corporation' and 'HKEY_LOCAL_MACHINE\Software\Sony Corporation' by right-clicking on the entries.4. Disabling any anti-virus software that is running in the background to free up some resources [if necessary]. Update your installation of Windows at Microsoft Windows Update. For Windows 2000 Professional users, you are recommended to upgrade to Service Pack 3 or later. Make sure that your unit is disconnected and install the latest build of SonicStage 2.3 from Sony Connect or Sony Connect Europe. The drivers for Sony units will automaticaly be installed. (If you use a Panasonic or Sharp Hi-MD/NetMD unit, install your drivers before you install the actual software!) Restart if prompted to do so; if not, it is still recommended that you do so. Plug in your unit, and start SonicStage.If not, uninstall, and reinstall using the above method. Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted January 27, 2005 Report Share Posted January 27, 2005 does it transfer any songs whatsoever? Quote Link to comment Share on other sites More sharing options...
mufc4eva Posted February 25, 2005 Author Report Share Posted February 25, 2005 Doesnt transfer no songs at all and I am using SP2..If anyone could point out possible solutions then that would be great Quote Link to comment Share on other sites More sharing options...
bobt Posted February 26, 2005 Report Share Posted February 26, 2005 Do your discs happen to have the record lock on?I have had a similar message when I get close to full and I try to transfer too many tracks.Have you tried S?imple Burner Quote Link to comment Share on other sites More sharing options...
