N10 Controller Backward Compatible?
Nacht Hund
I don't believe you will be able to access the menu options (by holding down the display button) on the stick remote when you are using a 2nd gen. (33EL, 35ELK) remote with a 1st gen unit (MZ-N1)
All the normal functions (track-skip, play/pause, track titles, etc.) should work fine.
For full compatibility, use the remote designed for the N1 (11EL, 12ELK.)
