Ss2.3
dj_bales
When I am using SS2.3, and I try to transfer a number of files after it gets a number of tracks in it gives me errors transferring. There is no problem converting, only transferring. When I do them one at a time this does not happen. I know there is plenty of room left on my MD as well. Has anyone else experienced this?
Have you checked your USB cable? I've read something like this before and in that case it was a bad cable.
Things to look for and avoid:
* USB hubs
* Other USB devices on the same controller/interface
* Background-running software for other USB devices that are loaded on system boot [including special mouse drivers, camera download utilities, &c.]
Just some ideas, incidentally ones that come from Sony tech support.
