Hi-md /simple Burner
lyceemoliere
wink.gif I recorded one hi md disc using cd---> HIMD with simple burner and the capacity seemed appropriate (i.e. about 40 cds seemed to fit on the disc). Then I tried to burn another disc and although I could not detect any changes in setting etc and the md side of the simple burner said "HI MD" and the transfer rate seemed to be the same, this time only 12 discs seemed to fit. What did I do wrong?
As I mull this over, am wondering whether this could be the problem: I originally recorded on this particular disc in md mode- then erased all the tracks. Does one need to reformat the disc- if so, how do I do this?
Edited by lyceemoliere
Sounds like you inititally recorded with the transfer mode in HiLP and then the second time it switched to HiSP. Check the little box in the middle of the SimpleBurner window, depending on your version you can get PCM/HiSP/HiLP/48kbps. (you may or may not see some of them). HiSP will get about 10-12 albums per HiMD disc, HiLP will get closer to 40.
I thought I recorded both with 48kbps actually. Which setting is best?
