Format
lyceemoliere
A HiMD 1GB comes formatted HiMD Mode because it cannot be used on older MD equiptment
However you can use older MDs on HiMD machines so you are given a choice between formatting it in MD Mode (can be played on old MD machines) or HiMD mode (doubles space but can only be played on HiMD machines)
Do do this to an older MD you can either use SonicStage while the MD is inserted in the recorder and the recorder is connected to the computer or on the recorder itself. On the recorder go to Edit > Format (if format is not present then go to Options > DiscMode > select HiMD, then go to Edit > Erase > Erase All
The disc will now be formatted in HiMD mode
