Changing Conversion Ss---> Himd
lyceemoliere
I am trying to save my small library on the himd discs. When I transfer the library I set the transfer rate to ATRAC 64. I selected all the songs at once for the transfer (select all). The first 7 songs were transferred using atrac 132 and the subsequent songs were transferred at 48kbps. Why is this? Why did the transfer format change in both directions from the default i had set?I checked my default setting and it still said atrac 64 at the end of this mysterious occurrence.
Is there any transfer fromat that is better if my goal is to transfer my library back after i upgrade to ss 2.3? (not for listening)
