Clicking Between Tracks
If the original format was MP3 (or another lossy format), then this happens because these formats are not gapless, i.e. there's a short silence between tracks. Some of these formats are gapless (for instance OGG), but SonicStage can't convert them anyway.
If you've ripped the original CD directly onto MD, then there's something wrong with your player/settings.
Have been using mainly wavs ripped from CD, then stored on my PC (well storage is so cheap now why not??).
Does the software that does the direct transfers from CD to MD need to be registered on the net before it can be used? I'm sure I've tried using it but couldn't get very far as I don't have my music/studio PC on the net and couldn't register it.
Thanks for the quick answer b.t.w.
Cheers.
Edited by silvermachine
