lindijones Posted September 28, 2005 Report Share Posted September 28, 2005 (edited) Hei ALL!!I want to sort/clean up my packages folder.If i do the function of cleaning up then still there are some empty folders which has no name.What is the Optimized files folder? I found some new recoded songs in there. I started one by double click. But it said in SS 3.2 that it´s a 132 Kbit/s ATRAC3 song. But if i look at the filesize it could never be 132 kbit/s.Whats going on?Are all the SEPERATE Albums there listed as SEPERATE Folders?How is the organisation??I have a mixture of file with and without copy protect, because of old and new ripped cds.Is there a possibility to find out which files have a copy protect and which not??Do i always have to use SS3.2 for checking this?Is there a possibility to kill the copy protect in one large step?I wrote that it works if you reencode it to the same format without a copy protect. But is it then recoded or is just the copy protection "filtered away"?Thank u!!!Tom Edited September 28, 2005 by lindijones Quote Link to comment Share on other sites More sharing options...
