Upgrading Sonicstage
palaceagles
can you post a link? The only place i see to download requires registering.
thanks.
Where is your location? If you are in Europe, you can download the full version of SonicStage 2.3 [EU] here [36.2 MB]. I believe this full version includes Connect Europe. If you care not for Connect and reside in North America or elsewhere, you can ignore the Music Service.
Good luck with your update.
Edited by Ishiyoshi
yes, Europe - thanks so much - this is great! With this installation can i choose not to install Connect Europe and just install SS 2.3?
is it a problem if i download the US version (and so don't get Connect Europe), even thou i'm in Europe?
If you choose to download SonicStage 2.3 via www.connect.com, you will still get North America Connect regardless. To answer your question, you should not encounter any problem. In addition, you can actually edit your SonicStage registry to change the default Connect location you desire.
