Rolloff Frequency Calculations
I'm planning to build a bass rolloff circuit for my microphones.
Can anybody give me some values to use for the capacitors
for these following rolloff frequencies:
50Hz
100Hz
200Hz
The output from this circuit would be the mic input or the line
input of my MZ-NH700 unit.
Does this unit have different impedance load on the two inputs
making me having to use different capacitors for the different inputs?
Thanks
50Hz
100Hz
200Hz
Thanks
How much roll-off do you seek? Half (=6dB cut)?
The equation for impedance (in ohms) is Z = 1 / (2*pi*freq.*capacitance (in Farads))
Now assuming the mic input is around the 1kOhm impedance mark, to halve the desired frequency into the MD would mean throwing in a further 1kOhm in the chain. So in that case, you would then plug in the value of 1000 for Z and your desired frequency in the freq. variable. The result will be:
1000 = 1 / (2*pi*50*C)
1000*2*pi*50 = 1 / C
C = 1/100000*pi
C = 3.18uF
So proportionally, for 100Hz it would be 1.59uF and for 200Hz it would be 0.80uF.
  thomasraden said:
Thanks for the answer. Does it matter if bipolar capacitors or normal electrolyte /tantalyte capacitors with polarity are used?
Sure will as that would affect the DC power being supplied to the mics. My advice is that you definitely stick with bipolar.
