HardcoreMd Posted March 19, 2005 Report Share Posted March 19, 2005 Hi guys, i'm new here and I got a really big probleme uploading song from sonicstage to my minidisc. ( model MZ-N510 TYPE-S)...I tried everything, but sonicstage just won't work, it always close itself saying the proram had an intern error... (i'm using windows xp btw)Anyway, my question is: Is there any other program that I could you to upload songs from my comp to my minidisc ?Thanks alot in advance :-) Quote Link to comment Share on other sites More sharing options...
scipio Posted March 20, 2005 Report Share Posted March 20, 2005 HardcoreMd said: Hi guys, i'm new here and I got a really big probleme uploading song from sonicstage to my minidisc. ( model MZ-N510 TYPE-S)...I tried everything, but sonicstage just won't work, it always close itself saying the proram had an intern error... (i'm using windows xp btw)Anyway, my question is: Is there any other program that I could you to upload songs from my comp to my minidisc ?Thanks alot in advance :-)←Forgive the simplicity but these are routine check and they sometimes work: Is SonicStage otherwise OK? If so, then uninstall and reinstall are probably not needed. Is the minidisc write tab closed? Is there room on the minidisc for the tracks selected? Is the battery charged? Does SonicStage transfer tracks you have not transferred before (try one only)? If so, have you transferred the ‘no-transfer’ tracks three times already (the permitted number)? Does SonicStage read the MD track list and show it correctly in the NetMD/Transfer window? Does SonicStage transfer from the MD correctly and remove the MD copy? If so, the USB connection is probably OK.Can you record from PC Lineout to MD LineIn using the PC soundcard? If so, the problem is localized to the USB connections, cable and SonicStage. Can you try a different USB connector, cable and MD? If these make no change the problem is localized to SonicStage and uninstall/reinstall is probably necessary (it may actually be one of the quicker tests).Recording to the MD, apart from licensed tracks through SonicStage/USB, is only in realtime using the PC LineOut and MD LineIn connections. Any soundcard/software can be used for making individual manual recordings. The Creative Minidisc Center software, however, can be used to compile an album from PC files and record it to the MD automatically, and the freeware winNMD from Christian Klukas (see the forum link) can checkout OMG files. You should be able to use the SonicStage Move function to move OMG tracks from the My Library to a PC folder for use with winNMD checkout.The cost of winNMD is 14 euros via PayPal. If the autoactivation from PayPal fails, email Christian and he will send the activation key. winNMD can also read the MD track list through the USB and then (MD LineOut to PC LineIn) play and record selected tracks to a PC folder automatically. Quote Link to comment Share on other sites More sharing options...
atrain Posted March 20, 2005 Report Share Posted March 20, 2005 okay when you say you've tried everything do you mean the full uninstall including the registry as noted in the stickies at the top of the forum?here is the address for the stickyhttp://forums.minidisc.org/index.php?showtopic=8071if you have done all of this please post back. if you haven't then get moving & keep us updated Quote Link to comment Share on other sites More sharing options...
