Sonicstage 3 Now Downloadable !
iddqd
1-You need to download WINRAR 3.40 (or latest ver)
2-Download these files (you can see download links at below)
3-Extract files into desktop with you winrar.
4-Execute files after download process (you can see files for execution at below)
;Microsoft Windows Installer Runtime
[MSI]
version = 2.0.2600.2
path = http://qw-cx-ssd.sonypictures.com/download.../common/msi.zip
execution = instmsia.exe
;DirectX 9.0c Runtime (if you have, do not download this)
[DirectX]
version = 4.9.00.0904
path = http://qw-cx-ssd.sonypictures.com/download...r/common/dx.zip
execution = dxinstall.exe
;Windows Media Format Runtime 9
[Wmf]
version = 9.0.00.2980
path = http://qw-cx-ssd.sonypictures.com/download.../common/wmf.zip
execution = wmfdist.exe
;Microsoft Database Access Runtime
[MDAC]
version = 2.51
path = http://qw-cx-ssd.sonypictures.com/download...common/mdac.zip
execution = mdac_typ.exe
;Music Server Controller
[MSC]
version = 1.1.00.10251
path = http://qw-cx-ssd.sonypictures.com/download.../common/msc.zip
execution = setup.exe
[Driver]
version = 1.0.09.11300
path = http://qw-cx-ssd.sonypictures.com/download...mmon/driver.zip
execution = setup.exe /NoAMI
[OpenMGSetup]
version = 4.1.00.13261
path = http://qw-cx-ssd.sonypictures.com/download...mmon/openmg.zip
execution = setup.exe /v"OMGCOREINI=OmgCore_US.ini"
[sonic]
version = 3.0.02.14170
path = http://qw-cx-ssd.sonypictures.com/download...er/us/sonic.zip
execution = setup.exe /NoUI
[Addon]
version = 3.0.00.14040
path = http://qw-cx-ssd.sonypictures.com/download...er/us/addon.zip
You can find these files in you temporary internet files, If you already used Sonicstageupdater.exe.
1-Return to desktop
2-Right on INTERNET EXPLORER Icon
3-Click properties
4-Click SETTINGS
5-Click VIEW FILES
(now you see a explorer window of your temporary internet files folder)
List your download files by size)
find zip files downloaded from http://qw-cx-ssd.sonypictures.com
Extract these files into desktop.
DONE!
Edited by dex Otaku
So you're saying that with these modules, I can setup SS3 entirely like as if I was running the installer on its own? This is assuming you're a SONY user (yes i know... most of the members are!), but for Sharp NetMD users like me, I think we need more modules... Sharp NetMD driver for one. Thanks though! Great find.
For those still having the open database problem on Windows XP /SP2 :
try to re-register mdac and jet with the MDAC repair tool found here :
http://www.macropool.com/en/download/mdac.html
It finally works for me !
[EDIT]
For reinstalling MDAC 2.81 on SP2 , see also :
http://www.macropool.com/en/download/mdac_xp_sp2.html
Edited by gigolo
[snip snip snip...]
the link with the dot...dot...dot doesn't work. It needs the full link typed out. With the dot..dot..dot..., it won't find the link.
And the web site address doesn't work neither. It can't find it. http://qw-cx-ssd.sonypictures.com/
Try the links again.
They were improperly pasted; I repasted them from the original post they were in, and they now work from here.
