Problem With My Player, Help.
Xerith
Well, I've had my mini disc player for over 5 months now. It's been working fine and everything but now its being really stupid.
I use real player to tranfer my music onto it, I've always used real player to tranfer music onto my mini disc player, but since yesterday It wont transfer any music onto my player.
It says, make sure there is a sufficient amount of space on your mini disc player (which there is, I even removed some songs and it still gives me the same message)
It also says make sure its the right format, (I tried many different times, with different songs and same message).
Then I tried using sonic stage, Sonic stage is converting the song, then gives me and error message and says its the wrong format. I've tried many different songs (even some songs that i've previously tranfered to my Md player.) And it still doesn work
I even tried un-installing real player, re-installed it and it gave me the same message. I don't get what happened, just a week ago I was using Real player to tranfer music onto my mini disc player, now this week it wont work.
I even tried using Nero, made an audio cd on my desktop, and mounted it. I used simple burner to tranfer the songs and simple burner gives me an error message saying that it cannot read the audio cd.
It's a NetMd MZ-n420D
Any suggestions?
Thanks.
i think you should take a look at the stickied topics at the top of the software & support forum. a proper uninstall & reinstall up to sonicstage v3.0 should fix the problems. could you also please post your system specifications inc. operating system details. updating to SP2 if you are a windows XP user could prove benificial too.
