kooterb Posted April 19, 2005 Report Share Posted April 19, 2005 I have a Sony mz-nh900, my question is this:If I use a battery box for my mics,Core Sound LCBand I choose not to use the manuel vol. setting,will the AGC and Mic sens still have an affect? and if so will, the AGC have a negative affect on the recording?I want to get as much as I can from the mics, but don't want to fiddle withthe Vol. control as most of my recording is stealth andmost of the time I can't adjust the Vol.Thanks for your time,Fred Quote Link to comment Share on other sites More sharing options...
Artstar Posted April 19, 2005 Report Share Posted April 19, 2005 Don't worry about it at all dude. Just plug in and away you go. Personally, I prefer not to use the AGC in my recordings because the dynamics in a concert can be so unpredictable that you don't know the next stupid thing the sound guy might do. That's where I leave it to my Soundforge to flavour the dynamics just how I need to, with hard limiters, gated compression, etc.But, having said that, I do recall recording an Anthrax concert last year on my MZ-R50 using AGC and it didn't turn out too bad, but that was mainly due to a well behaved audience in my vicinity and a decent/consistent job by the sound guy - he basically had it right the first time and it was unchanged.But depending on the expected volume at the gig, make sure you choose the right socket for the job - line in or mic in. Given the fact you're using a battery box, if it's a moderate - loud environment, I would strongly recommend you plug into the line in. If you are going to a comedy club or something, then the mic input with low sensitivity would be the way to go.Nice choice of mics too. I have the Core Sounds premium mics (before he released a low cost version - 1998!) which have served me well at the loudest of rock concerts but now I want to take it the next step higher with his mucho $$$ stealth mics. Best of luck dude. Quote Link to comment Share on other sites More sharing options...
kooterb Posted April 19, 2005 Author Report Share Posted April 19, 2005 Thanks very much for the input, I'll give it a try. Artstar said: Don't worry about it at all dude. Just plug in and away you go. Personally, I prefer not to use the AGC in my recordings because the dynamics in a concert can be so unpredictable that you don't know the next stupid thing the sound guy might do. That's where I leave it to my Soundforge to flavour the dynamics just how I need to, with hard limiters, gated compression, etc.But, having said that, I do recall recording an Anthrax concert last year on my MZ-R50 using AGC and it didn't turn out too bad, but that was mainly due to a well behaved audience in my vicinity and a decent/consistent job by the sound guy - he basically had it right the first time and it was unchanged.But depending on the expected volume at the gig, make sure you choose the right socket for the job - line in or mic in. Given the fact you're using a battery box, if it's a moderate - loud environment, I would strongly recommend you plug into the line in. If you are going to a comedy club or something, then the mic input with low sensitivity would be the way to go.Nice choice of mics too. I have the Core Sounds premium mics (before he released a low cost version - 1998!) which have served me well at the loudest of rock concerts but now I want to take it the next step higher with his mucho $$$ stealth mics. Best of luck dude.← Quote Link to comment Share on other sites More sharing options...
