Which Md Should I Choose ?
theBrave
Hello,
I'm a French student and I wanted a way to travel with music. First I thought about an MP3 USB key. But I wanted to spend less than 80 €. With this amount I could only buy 256 (maybe 512) megabytes of storage.
Then I thought about MD. I used to own a recorder (this was before the Net MD era) which was very expensive. So I was very surprised to find on eBay some simple units (N420D) for less than 50$.
If I remind well, using LP4 compression I can hold more music than a 256 MB keys and cost less than 3$.
I was then once more surprised when I discovered that I could buy an HiMD recorder, the NH600D for 30$ more. But:
- The 420D “psyc” version is much prettier
- Battery life is far lower
Which one should I choose?
And ...
I have some more question about both units:
- are they powered by the USB port when downloading music to the device?
And specifically about the HiMD one:
- do I need drivers to use them as storage devices?
- could I use standard (74 or 80 Min) discs and put files on them, or this functionality is limited to HiMD discs ?
- how much music could be put on 1GB disc when I want LP2 quality ?
1/ nope, not on systems that use UMS so windows98se up, macs & most linux
2/ yes you can use 'old' discs, as standard disc or reformat them to himd & the capacity is doubled
3/um, heaps. there are some faqs on the front page.
make sure it's nh600 not nh600D & you'll be able to record from radio, cd & other inputs aswell.
