M-audio Drop The Bomb
grimleyj
Damn ... feck ... sh**e ...
I JUST got my rh-10 (strictly for sampling purposes) and then MAudio announce this ...
New MAudio recorder
The rh-10 is OK for my purposes except downloading linear PCM from the device is S-L-O-W !!! I was under the impression that I could just drag and drop from windows explorer and over USB it would be reasonably quick. I couldn't believe it when I saw that the amount of time to transfer to the PC as as long as the actual recording. Ahh well, it will do in the short-term.
-grimley
New MAudio recorder
-grimley
Oooooo.... I hope it goes into production!
  kurisu said:
What're the specs on your PC, grimleyj?
Not exactly cutting edge, here's the lot:
P4 2.4
Asus P4PE
Windows XP Pro (tweaked for audio recording)
1GB PC2700
2 x 250GB SATA RAID 0 (audio)
1 x 100 GB ATA133 Samples
1 x 80 GB ATA133 System
1 x 250GB external USB 2.0 (Backups)
Matrox P650 dual head
RME HDSP 9652
2 x UAD-1
1 x TC PoCo (PCI)
Midex 8
-grimley
Obviously no one's there to see how slow it is for you, but for PCM it isn't expected to be fast. It'll be faster with smaller files - ie, atrac recordings, particularly hi-lp. You must remember PCM recordings are large, and the HiMD magneto-optical discs aren't fast.
