FrzzMan Posted April 23, 2005 Report Share Posted April 23, 2005 As I don't need mic-in or line-in, I think I should go for the NH3D cause it cheaper.But I really don't know what is the differents between NH1 and NH3D (beside mic-in and line-in)Anyone here please help, thank in advance. Quote Link to comment Share on other sites More sharing options...
sebastianbf Posted April 23, 2005 Report Share Posted April 23, 2005 (edited) As I don't need mic-in or line-in, I think I should go for the NH3D cause it cheaper.But I really don't know what is the differents between NH1 and NH3D (beside mic-in and line-in)Anyone here please help, thank in advance.←hellowhat do you want the unit for? if you're looking to edit music, it is not possible with the nh3d but if you want a unit just to listen to your downloaded songs you should get the nh3d. it seems that the construction of both units is very similar. tell me what do you want the unit for so i can help you.*note that only the nh1 has a lcd screen on the unit.sebastiancheck this:http://www.minidisc.org/part_Sony_MZ-NH3D.htmlhttp://www.minidisc.org/part_Sony_MZ-NH1.html Edited April 23, 2005 by sebastianbf Quote Link to comment Share on other sites More sharing options...
FrzzMan Posted April 25, 2005 Author Report Share Posted April 25, 2005 Well, the main purpose of this purchase is I want to replace my NH600, which is only 2 weeks old My NH600 have line-in (optical) which I do not use, and remote port which I do not use (cause I haven't purchase a seperate remote yet)...Basically I only use NH600 for download music from my PC and listen to the downloaded music when I'm travelling (I travel a lot)But the NH600 is too big, it's weight is not a problem since it's light, but it's too big for me to carry around and it doesn't have a remote, so I have to take it out of my bag anytime I need to use it, so inconvenient.Btw, I decided to buy the NH3D since it's only $169, and the NH1 is $329 8-|Hope it will replace my NH600 well, thank you. Quote Link to comment Share on other sites More sharing options...
Tiesto Posted April 26, 2005 Report Share Posted April 26, 2005 Btw, I decided to buy the NH3D since it's only $169, and the NH1 is $329 8-|... ???... tell me, exactly, where did you find the NH3D for that price??!!!... perhaps, I should start a garage sale to get one of those Quote Link to comment Share on other sites More sharing options...
FrzzMan Posted April 26, 2005 Author Report Share Posted April 26, 2005 (edited) I live in Vietnam...It's not that easy to buy Hi-MD stuff here, one of my members (I'm an admin of a forums) import them and sell them on my forums.It's brand new in box, Japan version (but the cradle doesn't have the usb in)Just have it today, but I don't know what to do now, maybe the battery is dead :cry:Please take a look @ my thread outside :cry: Edited April 26, 2005 by FrzzMan Quote Link to comment Share on other sites More sharing options...
