hoob Posted April 27, 2005 Report Share Posted April 27, 2005 I've had a Sony MZ-S1 for nearly 3 years now. It's been real good to me and everything. Never had any problems with it. Until today. I was transferring some songs to it using OpenMG Jukebox. And as soon as I transferred all the songs and went to listen to them, the player told me the disc was blank. I was a little confused, but listened to an old disc with other music instead. When I got home later and tried it again, it ended up doing the same thing. Everytime my player turns itself off after a music transfer it wipes the disc clean. I tried it with Simple Burner and Sonicstage also. The same thing. I'm not sure what to do with it now. I'm hoping it's a software issue, but the more I look at it, the more it seems to be the player itself. It's rather worn and all, but I didn't think it would do that. It also has started to turn itself off when the cover is clicked open to access the minidisc port and battery slot. It never did that before, but now it's starting to. I'm afraid this is all leading to the death of my player. I just hope it's something else. Has anyone else had these problems or something like it? Anyway, thank you for whatever help you can afford. Quote Link to comment Share on other sites More sharing options...
Syrius Posted April 27, 2005 Report Share Posted April 27, 2005 Sounds like a bad write block. Try making a recording through the line-in jack, and if it gives you the same problem, then it's the unit the one that's going bad. Keep in mind these are high-precision electronics, and are subject to wear and tear. Quote Link to comment Share on other sites More sharing options...
hoob Posted April 27, 2005 Author Report Share Posted April 27, 2005 I'll try that. Hopefully, it isn't...Thanks for the tip. Quote Link to comment Share on other sites More sharing options...
Christopher Posted April 27, 2005 Report Share Posted April 27, 2005 If you can record that way, then you need to dump the old old old old OpenMG and upgrade to Sonicstage 3.1 - links are in the pinned topics at the top of this forum. Quote Link to comment Share on other sites More sharing options...
