Hiceiling Posted April 29, 2005 Report Share Posted April 29, 2005 This may seem like a stupid question, but will the MZNH600's LINE IN (optical) work with some kind of mic? like a powered mic? I know I cheaped out and bought the low end model, but I could not pass it at $50....Figured it wouldserve as a good intro.Thanks in advance for your help! p.s. I am using Sonicstage 3.1 and converted all my MP3s to atrac with the converter...works fine if you have the disc space!! Quote Link to comment Share on other sites More sharing options...
mrsoul Posted April 29, 2005 Report Share Posted April 29, 2005 Sure you can use a powered mic with that line input. Are you sure you have the 600, not the 600D? The 600D is the US version and only has the USB input and is a downloader only. The 600 was Europe only, I think. Quote Link to comment Share on other sites More sharing options...
Hiceiling Posted April 30, 2005 Author Report Share Posted April 30, 2005 mrsoul said: Sure you can use a powered mic with that line input. Are you sure you have the 600, not the 600D? The 600D is the US version and only has the USB input and is a downloader only. The 600 was Europe only, I think.←Yes, I am in Paris.....thanks....It is the european model 600... and the volume seems good too. I had heard the European models were not loud enough, I am using Koss The Plug earphones and usually only have the voume up to 16 or 17.I will look for a mic and try to record a show here..Plus the JVC Jazz festival starts in June. Quote Link to comment Share on other sites More sharing options...
