Problems With Sony Nhf800
troubled
hello md community
I started with a sony MZN707
user posted image
it was great. I loved it. It was stolen
Now I have stepped up to the MZNHF800 as soon as it hit the market
user posted image
it was great. I loved it. It quit working.
when I pop in a disc, it spins but it is like it doesn't find where to start. It just spins and makes an out of the ordinary ticking noise. I can skip tracks, but they never play. It says something like "busy please wait" this happens with 1g and 80 minute disks. I even made sure to have it in the respective play mode. I tried taking out the battery, but nothing works.
Should I try a cleaning disk?
Should I forget it and buy a new one?
user posted image
Does anyone else have this trouble?
please help. Thank you
this problem has occured with a 1g disk, and an 80 min disk. those are the only ones that I have tried. I don't think that it is underwaranty, I bought it from minidisco right when it came out maybee on the 2nd shipment. I did drop the unit once from about waist high months ago, and it has worked fine since then so I don't think it was damaged.
