Sony NetJuke PC Stereo: NAS-A1
mercury_in_flames
Well it sure looks tastey, but at a mere 35 watts rms per channel well.. :ol_blankstare:
Source: Sony NetJuke PC Stereo: NAS-A1
himd_idx.zip himd_idx_src.zip
System Specifications
HDD Module
Capacity: 40GB
Supported Format: ATRAC3 (66/105/132kbps), PCM
Management System: supports up to 200 folders, 2,000 albums and 20,000 music files
CD-->HDD recording speed: approx. 8x speed (with audio monitor OFF) and 6x (with audio monitor ON)
CD Module
Supported format: CD-DA and Mp3
Audio quality: 20Hz-20kHz (±1.0dB)
Memory Stick Module
Supported format: ATRAC3 and Mp3
Memory Stick Pro Slot: MagicGate compliant
AM/FM Tuner Module
Frequency: AM: 531-1,602kHz and FM: 76.0-90.0MHz
Photo Album Module
Supported file format: JPEG, GIF, PNG, TIFF and BMP
* up to 5,000 pictures
* support slide show
Web Browser Module
HTML and Flash: HTML 4.0 and Flash version 5.0
Input/Output Terminal
Network connector: 100BASE-TX/10BASE-T
USB: 2
Audio Input/Output: 1/1
Headphone Output: 1 (front panel)
Video Output: 1
Amplifier
Capacity: 35w×2
Power source: AC100V and 50/60Hz
Size: approximately 235 × 119 × 330mm (w/h/d)
Weight: approximately 5.6kg
Speaker system
Type: 2-waybus reflex, woofer 10cm×1, tweeter 2.5cm×1
Size: approximately 130 × 325 × 200mm (w/h/d)
Weight: approximately 2.5kg
*edited by Ishiyoshi
4 answers to this question
