Protect Your Oled Screen (rh10)
In order to protect my OLED screen on my RH10, I am using a very cheap trick that does not lower the screen visibility and keeps the scratch risk very low. I had a roll of that static cling tint for automobile windshields (the thin strip that runs across the top). I cut a square a little bigger than the OLED and placed it on the RH10. Sticks very tightly and no residue to ever worry about for this trick. I can always cut another piece if this one suffers.
The only down side is the visibility in direct sunlight has not improved with this trick. You will need to shade it to see in direct sun. But then again, I can hardly see the OLED in direct sunlight anyways. That's where my RH910 comes in real handy! The old fashion LCD wins every time in the sun!
Just thought I would share my trick if anyone out there is worried about their OLED! wub.gif
