mddude Posted May 22, 2005 Report Share Posted May 22, 2005 is there any programs that allow me to save recordings from my mini disks to my pc? i have a net md player but i used to have a normal md recorder of which i created alot of disks and i want to save my recordings to my pc rename them and organise them and put them on to 1 disk. Quote Link to comment Share on other sites More sharing options...
zerodB Posted May 22, 2005 Report Share Posted May 22, 2005 Nope, it's not possible to use NetMD to transfer from MD to PC.The only way to do it is to record from MD to PC in real time. The program "WinNMD" can assist you in doing this, by using the USB to ascertain track lengths and titles - look at the stickies in this forum. Quote Link to comment Share on other sites More sharing options...
Andicillo Posted May 24, 2005 Report Share Posted May 24, 2005 is there any programs that allow me to save recordings from my mini disks to my pc? i have a net md player but i used to have a normal md recorder of which i created alot of disks and i want to save my recordings to my pc rename them and organise them and put them on to 1 disk.←There are some softwares that makes it very esay to save your mds in your PC I personally bought Christian Klukas WinNmd and it worked like magic I uploaded all my old MD's before moving to HI MDYou can download it from the following linkhttp://winnmd.net/You will love it Quote Link to comment Share on other sites More sharing options...
zerodB Posted May 24, 2005 Report Share Posted May 24, 2005 Yep - that's the one I was referring to.Note that if you record your MDs to PC, then re-record or transfer that music to MD (or MP3, or any other compressed format for that matter), you will incur a generational quality loss as your music is being re-encoded. Quote Link to comment Share on other sites More sharing options...
typischdenis Posted September 30, 2007 Report Share Posted September 30, 2007 Hello,this Program it's very nice. But we can I activate this tool. The Activation link is not worked.Please help me.Thanks Quote Link to comment Share on other sites More sharing options...
Avrin Posted September 30, 2007 Report Share Posted September 30, 2007 The program is somewhat obsolete now, since you may use the MZ-RH1 to upload your MD recordings to a PC faster than realtime and without any quality loss. The only exception is that you cannot upload the music you downloaded to a NetMD using SonicStage. Recordings from external sources (Mic, Analog, or Optical input) upload just fine, and you can even upload from pre-recorded MDs. Quote Link to comment Share on other sites More sharing options...
A440 Posted September 30, 2007 Report Share Posted September 30, 2007 WinNMD seems to have been abandoned years ago. But Hi-MD Renderer, which you can find in Downloads on the upper right, has the same function and it's free. Install it, connect your NetMD with both USB and headphone-out-to-Line-in, and click on MD Recorder. Quote Link to comment Share on other sites More sharing options...
